Old 08-03-2013, 05:10 PM   #1
BurntOrangeT2
No phonebook but OG calls
BurntOrangeT2's Avatar
BurntOrangeT2 is on a distinguished road
Open to Reasonable Offers
Please Email for fastest response: cdevers2011@gmail.com
PayPal is: vickidevers@yahoo.com
> (2) RC Engineering 550's, 2K Miles, flow wonderfully - $150 shipped
> (2) Denso 680's, mileage unknown - $80 shipped
> (2) Bosch 1680's, about 10K Miles, - $200 shipped (injector cleaning from RC is $24 per if u want, still come out ahead of buying new)
> BNR upgraded wastegate actuator - $100 shipped
> ACT 6 puck, sprung hub W/ HD pressure plate (Z65-HDG6), S4, great clutch disc life left, was replaced less than 200 miles ago - $300 shipped
> ACT Streetlite Flywheel, S4, will need a resurface - $215 shipped
> ACT rear counterweight, S4 - $120 shipped
> Spec Stage 1 Clutch, great disc life left - $225 shipped
> Racing Beat Aluminum Double Sheave, main pulley - $75 shipped
> Reman O'Reilly's FC Alternator with Racing Beat Double Sheave aluminum alt pulley, lifetime warranty - $100 shipped
- 1 S4 T2 turbo, no shaft play, small cracks in rear mani, great BNR candidate - $100 shipped
- 2 S5 Exhaust manis, ok condition - $50 shipped for one w/ all the turbo studs $40 for the one with 3 studs.
- 5x leading 2x trailing T2 coils - $30 each shipped
- 3x CAS sensors - $25 each shipped
- 1 pair of S5 fuel rails, great condition - $35 shipped
- 2x '87 T2 ECU's - $45 each shipped - 1 SOLD, 1 LEFT
- 1 stock T2 top mount IC - $30 shipped
- 1 NEW S4 T2 LIM to block Gasket - $10 shipped
- 1 set NGK stock plug wires unknown mileage - $15 shipped
- 1 S4 Engine harness, only good for connectors if terminating a standalone. will sell - $5 shipped per connector or $20 shipped for entire harness
- 2x shifter surrounds, both plastic not rubber - $10 shipped
- 1 logicon, worked when pulled, will need to crimp - $15 shipped
- 1 set of S4 turn signals - $15 shipped
- 1 S5 drivers side electric mirror, great condition, needs paint - $35 sipped
- 1 T2 hood scoop insert, good condition, will need some reconditioning, all mounting points intact - $90 shipped
- 1 grey S4 T2 glove box, decent condition - $20 shipped
- 1 Complete Grey S4 T2 rear carpet w/ Bins - $75 shipped
- 1 set of Great condition S4 tails, No cracks or chips, color fading is apparent - $150 shipped (PENDING)
- 1 S5 drivers side tail light, decent size chips - $20 shipped
- 1 S5 passenger side tail light, has chips - $30 shipped
'89GXL - S4 T2 Swap, body work complete, time for paint.
BurntOrangeT2 is offline   Reply With Quote
