#1 | |
Get off my lawn!!!
Rep Power: 15 ![]() |
And quit calling people "pugilists", it makes you look like more of a fucking asshat! Just trying to help.
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
#2 | |
rotary owner/driver.
stop f.....g up the threads. go f..k up your own. get lost knuckle dragger !![]()
#3 | |
#4 | |
(Although this forum does not have an explicit Terms of Use / rules for members (maybe we should have one?), it's understood that members would conduct themselves in a reasonable manner. If you have no idea what this means, this is the top Google search hit for "online forum etiquette": http://www.webopedia.com/DidYouKnow/..._etiquette.asp I highly recommend you go read everything there.) EDIT: I've added the "Rule of Conduct" sticky in here - NO EXCUSE; READ IT. Note that "Trolling" calls for an instant ban... NOW, this is a TECH subsection... There is no reason to be using vulgar and foul language. Just because your swear word isn't explicitly spelled out, it doesn't mean you're out on a technicality. If it's obvious you're trying to swear - even if you're missing letters, etc. - it will count against you. THIS IS YOUR INITIAL WARNING ON THE BAD LANGUAGE AND HARASSMENT OF OTHER MEMBERS. Keep this up and further discipline and / or restrictions to this forum will ensue. It looks like you can't get it into your thick skull that you seem to be the source of the problem, as almost all of your threads and replies find themselves degenerating into the dumpster. So it looks like your initial friction with me was not an isolated incident. You've already developed a bad reputation on here by several established members, so that puts you in a bad spotlight. If you have any intention to stay here, I'd highly suggest you alter the way to address your replies. If you can't keep your attitude in check - or none of the above makes sense to you - I'd highly suggest to find another online forum to go irritate... Since you like "No Pistons," might I suggest NoPistons.COM? -Ted Last edited by RETed; 07-17-2013 at 10:58 PM. |
