| RX-8 (2004 - Present) All things to do with RX-8 |
#1 | |
Your engine is designed to work most efficiently at a certain temperature RANGE. If you're trying to run it too cold, you're just wasting fuel and possibly causing premature engine wear - hell, why would you care cause you advocate shutting the engine off after revving it up to 3k+ RPMS! Unless you're having overheating issues - are you? - there's no reason to be changing anything, including the radiator. A larger radiator does nothing if your previous radiator worked fine. If your previous radiator worked fine, then upgrading to a larger radiator just causes the thermostat to possibly work harder and possibly fail prematurely. -Ted |
BOILED PEANUTS!!!
Why are you wanting to install a secondary radiator? Are you having cooling issues now? If so the issues causing that needs to be remedied before any modifications are done. On to the answers to your questions:
Oil temps do not turn on the fans, coolant temps do, and they turn on at around 210 F. Rx8performance.com sells a relay kit that turns them on at 185 F, I have that on my car. For the oil temp sender I found it best to get a modified banjo bolt that you can screw the sender into and us it to replace the banjo bolt either on the front cover or drivers side oil cooler (put it on the side pre-cooler not after) You can get an oil filter sandwich adapter but I found that the oil filter location made the thing a bitch to deal with.. I ended up throwing mine across the driveway in frustration and ordered the before mentioned banjo bolts. Again, Scott at Rx8performance.com made those for me. All in all the cooling system on the rx8 is very good if functioning properly, unless you live in extreme heat or track the car it should be fine. Do you have a undertray that is intact? it is an essential part of the cooling system
![]() www.rotarycarclub.com "The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot." |
#3 | |
rotary owner/driver.
#4 | |
BOILED PEANUTS!!!
#5 | |
#6 | |
?. You sound almost angry?.
#7 | |||||||||
Let me just preface this...
I've been dealing with newbs like you for years now. I've been dealing with newbs like you online for over 20 years now. I can smell them from a mile away. You think you know what you are doing. In actually you have a lot to learn. You know just enough to be dangerous. You also have a chip on your shoulder that if you get criticized, you get all defensive and get all butt hurt. Get over it. You asked a public question on a public forum - be prepared for responses that you do not agree with. Quote:
If you're buying and swapping stuff just for the sake of doing so, then none of this applies to you and just ignore anything I say, period. When I build my cars, I change and mod things that NEED to be modded - nothing more; nothing less. My philosophy is: function over form. Quote:
Since we're comparing resumes... Quote:
You made your point. I came to the conclusion that you're not going to listen to anything I had to add, thus, I ended my involvement in that thread. Quote:
Ask anyone who has known me for a few years - my road is littered with ignorant people like you...thousands... Angry? You're giving yourself too much credit. I'm sitting here smilin' and laughin' at how much you don't know... Try again. Quote:
-Ted |
#8 | |
Wow! me too. If you don't have an 8 its probably best you do not comment on the 8. Make sense ted. Here is a nice 1st generation 7 Last edited by rotar bones; 08-04-2013 at 04:14 PM. |
