Old 06-09-2013, 08:55 PM   #1
GtoRx7
GtoRx7 is on a distinguished road
All the new seals. Too much time in clearancing side seals. I always dread it
The ultra ultra lightweight clutch and flywheel. 4.5lb flywheel and 9lb clutch. Alcon makes one sexy setup
DEFINED AUTOWORKS
Where concept meets results
Black 1994 FD 4-rotor 610rwhp all motor
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Black 1984 Gsl-SE 13b-re streetport 230rwhp
GtoRx7 is offline   Reply With Quote
Old 06-09-2013, 08:56 PM   #2
GtoRx7
[b] The IV-rotor housings next to the workhorse 3-rotor semi p-port housings.
And of course, the triple spark plugs.
DEFINED AUTOWORKS
Old 06-09-2013, 09:00 PM   #3
GtoRx7
Some of the machine work for the center stationary gears
I wanted to save weight everywhere possible, and also make our 4-rotor look more "factory produced". So I shaved the center irons, which took some time to do.
As stated earlier, there are SO many things inside the engine that I cant photograph unfortunately. The intake ports, the exhaust ports, internal cooling methods. All this made taking engine assembly pics impossible. Sorry guys! Here she is all finished and assembled.
I made a fast custom engine stand to assemble the beast. Took a minute to think of a good way to do it.
The drysump plate all bolted on and ready to scavenge some serious oil
DEFINED AUTOWORKS
Old 06-09-2013, 09:02 PM   #4
GtoRx7
Temporary waterpump installed, front drysump pulley, custom trigger wheel for the electromotive
Think that is enough mag sensors? lol
DEFINED AUTOWORKS
Old 06-09-2013, 09:03 PM   #5
GtoRx7
Coil mount finished (12 coils..... whew) And the slide throttle fully machined and finished. The slider is out, while I fabricated the intake manifold.
Does this look like a machine or what?? The R26b would be proud. Notice the very straight shot intake manifold. This was the reason for all that chassis modification.
Wanted a nice lightweight alternator relocation bracket, so designed this one. All cnc of course. The aluminum front irons do not have any bolt provisions, so mounting brackets are little more difficult.
DEFINED AUTOWORKS
Old 06-09-2013, 09:04 PM   #6
GtoRx7
This is an endurance engine through and through, so I had to think out extensive planning on cooling methods. Having 1.5 years timeframe, it gave me time to come up with very clean and creative ideas. Here is a pic showing all the coolant feeds, and oil feeds. Once nice tight package considering there is 15 lines there!
CNC oil port plugs. Had "DAR" cut into them. Defined Autoworks Racing of course
Had to go old school on this one, the ITB airhorns were anodized the same green as my very first 20b back in 2004.
Another challenge was the variable intake. Uses metals that cant be welded, so I had some split flanges cnc cut. Notice the counterbore, this gave 1/4" more travel on the intake.
DEFINED AUTOWORKS
Old 06-09-2013, 09:06 PM   #7
GtoRx7
The famous n/a 3-rotor weight (same type 5.5" clutch, waterpump, lightweight flywheel etc. ) Impressive at 279lbs.
With t-5 dogbox tranny is at a low 376lbs.
And here is the assembled 4-rotor, 285 lbs. 6lb increase over race 20b.
And also weight with ultra heavy duty mid valley transmission. Still only 7lbs heavier.
DEFINED AUTOWORKS
