Show your rotary car build up. Show off your Rotary Car build! |
Coming together now
![]() ![]() ![]() Sanded the whole engine bay, removed all the seam sealer. ![]() ![]() ![]() Primer! ![]() Gotta have my signature GREEEN!! ![]() ![]() ![]()
DEFINED AUTOWORKS Where concept meets results Black 1994 FD 4-rotor 610rwhp all motor Red 1970 Mazda R-100 with 10a Black 1974 Mazda Rx4 Black 1984 Gsl-SE 13b-re streetport 230rwhp |
Bet you guys didnt think this was possible based off the beginning huh? I'm not a professional painter, but many guys who have stopped by think I am
![]() ![]() ![]() This one goes to Matt, he came up with using a motor plate idea. I liked it, and started to fabricate using the dummy engine. This made the whole package so easy to install and remove ![]() Now onto the 4-rotor! After all that is what everyone wants to see. 1st off the aluminum side housings. So light, so nice. ![]() ![]() The ultra-light rotors ![]() P-port all epoxy sealed ![]()
All the new seals. Too much time in clearancing side seals. I always dread it
![]() ![]() ![]() The ultra ultra lightweight clutch and flywheel. 4.5lb flywheel and 9lb clutch. Alcon makes one sexy setup ![]()
[b] The IV-rotor housings next to the workhorse 3-rotor semi p-port housings.
![]() And of course, the triple spark plugs. ![]() ![]()
Some of the machine work for the center stationary gears
![]() ![]() I wanted to save weight everywhere possible, and also make our 4-rotor look more "factory produced". So I shaved the center irons, which took some time to do. ![]() As stated earlier, there are SO many things inside the engine that I cant photograph unfortunately. The intake ports, the exhaust ports, internal cooling methods. All this made taking engine assembly pics impossible. Sorry guys! Here she is all finished and assembled. ![]() I made a fast custom engine stand to assemble the beast. Took a minute to think of a good way to do it. ![]() ![]() The drysump plate all bolted on and ready to scavenge some serious oil ![]()
Temporary waterpump installed, front drysump pulley, custom trigger wheel for the electromotive
![]() ![]() ![]() Think that is enough mag sensors? lol ![]() ![]()
Coil mount finished (12 coils..... whew) And the slide throttle fully machined and finished. The slider is out, while I fabricated the intake manifold.
![]() ![]() Does this look like a machine or what?? The R26b would be proud. Notice the very straight shot intake manifold. This was the reason for all that chassis modification. ![]() ![]() Wanted a nice lightweight alternator relocation bracket, so designed this one. All cnc of course. The aluminum front irons do not have any bolt provisions, so mounting brackets are little more difficult. ![]()
Bookmarks |
