| 20B/3 Rotor Conversion.. All things to do with 20B/3 rotor... Post pics, video, tech, etc.. |
Don Mega
who did the 3 plug conversion for you and what ECU you running?
how much HP will it make you think? downloading vids now, tissues on the ready
The Ancient One
diabolical1... Ha-ha. Now, that's creative as hell. Thanks. This is literally the start up and I actually expect it will sound much better when we get it done. Just the sound of the ITB's sucking should add a bit...
riceracing... Logan Carswell at Defined Autoworks did the 3 plug conversion. I'm still running my Microtech Ltx12 with an outboard x6 Igniter added for the extra plugs. I'm running the leading and trailing 1's with no split. As to hp, I don't know, of course, until its on the dyno, but would guess 375+ to the wheels. Most of the design changes I've made were intended to improve torque at lower rpm, including the dual path exhaust pipes and the secondary intake butterflies. I'm handicapped on max power, because I didn't want to dry sump the motor and go with ceramic seals. So, I have an 8500 rpm nominal redline. I think I could pull 400 if I ran to 9500 rpm. But, again, we'll just have to wait and see. Modified Magazine is covering a test & tune day at VIR on Monday, May 20th and in addition to track testing we'll have it on the dynos down there. We will have already done some pulls, but the motor should have close to 1500 miles on it by then and the numbers should be pretty stable. We're also testing a stock FD, a modded twins FD, a 20b turbo and a 4 rotor NA. Should be very interesting to see how they all handle and what the lap times are. G
1993 Rx7 R1 20b NA 1994 Rx7 20b supercharged project 1991 BMW 850 6 speed 1991 BMW E30 M3 Evo II Last edited by gmonsen; 04-26-2013 at 08:44 PM. |
Is this going to be supercharged like your sig says?
This is going to tear |
The Ancient One
Hades... No. Separate project and way behind on it. This motor is the 1st one in my sig. It runs three 55mm ITB's. The supercharger project is to build a similarly "linear" power delivery motor to my NA, but aiming for 500 whp instead of a bit below 400 on the NA motor. I also like the whine of a supercharger. However, I am no longer sure I want or need more power than what I have or will have in a few weeks.
![]() G
1993 Rx7 R1 20b NA 1994 Rx7 20b supercharged project 1991 BMW 850 6 speed 1991 BMW E30 M3 Evo II |
The Ancient One
Update... So, tomorrow we'll have the new intake and ITB's on. So, we'll get another start up by end of week with the completed motor and exhaust. Should be good.
G
