Old 04-23-2013, 08:21 PM   #1
Mutaku
Gen. Yoloswaggin Baggins
Mutaku's Avatar
Mutaku is on a distinguished road
Thank you, I'm making a point, it's a solder joint on the board issue... my point being, a bad trigger signal can kill an engine, seen it many times, so why chance things is what I'm getting at
Wrong
Stand meecrowreck up in field
Shoot with various Kimbers, HK's and Saiga's
Throw remaining bits in trash
Problem solved
Fucking hate those stupid boxes.... good for ITS n/a race cars and that's about it....
I get what your getting at. What it really comes down to is doing things right with the tools required. Honestly in a car situation I don't see anything that crimps can't take care of ;-P
Mutaku is offline   Reply With Quote
Old 04-23-2013, 09:24 PM   #2
Originally Posted by Rotary Evolution View Post
they're bad but they're not THAT bad...
Use the ECU that I learned on and come back and talk to me
I agree, which is why I only crimp
Old 04-23-2013, 09:55 PM   #3
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
it's a basic ECU, easy to setup and just as quick to tune. i haven't seen one fail and many have run reliably for many many years that i installed and tuned.
the downside is the nickel and diming, firmwared anything into the units, the retarded narrowband input factory option and the older than time dongle w/o write to disc(supposedly they did step into the 20th century recently with the new version).
does it work? yes, very well.
is it the best ECU out there now? fuck no. though it's only been recently that some other ECUs are giving them a hard time about being the cheapest ECU still on the market(no, i still don't consider MS a comparable option either even though it is cheaper, or that Rtek garbage).
and it depends on which car you are installing it on and whether you care about re-using 20-25 year old wiring. most of the cars i work on have almost zero realistic plug-n-play options. though it doesn't bother me much, because building a high performance car with the original harness always leaves me a little uneasy.
http://rotaryevolution.net
Old 04-23-2013, 10:08 PM   #4
Mutaku
Mutaku's Avatar
I usually just say I crimp on aircraft so you should just crimp your car. If I go any deeper people get all retarded lol
