Old 05-12-2008, 04:50 PM   #1
Kentetsu
Kentetsu's Avatar
The front control arm bolts to the crossmember. The other end is at the bottom of the shock. If you look at the area where it attaches to the crossmember, well that is where the bushings will go.
Fix your fuel filter. Not sure what effects it would have with it on backwards, but there must be a reason for the flow direction...
