OP - are you absolutely sure its coming from the coolant temp sensor area and not somewhere above it? Reason I point this out is if the O-rings under the oil pedestal blow out, it will flow down, make a mess and possibly look like its coming from the area the coolant sensor bolts into the rear iron.
