Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotary Diagnostics Systems
Rotary Diagnostics Systems Our Rotary-engine Compression Testers combine off-the-shelf hardware and software to create a reliable system that can be used to obtain accurate engine compression measurements from a rotary engine. www.rotarydiagnostics.com P.O. Box 524 Mont Alto. PA 17222 (717) 352-7096
Old 03-26-2013, 10:41 PM   #1
Dannobre
Dannobre is on a distinguished road
I have had one for 4 years...works well....It is much more complex than the Mazda tester to use the first time..but after you have done it it is quite easy
It also gives you more data than the Mazda tester...
Dannobre is offline   Reply With Quote
