#31 |
RX-7 Bad Ass
#32 |
Gold Wheels FTW
SSV valve replaced.... STILL TICKS....
I'm starting to think it's just a byproduct of the bridge port. Since there's overlap now, maybe there's a surge being pushed up the secondaries, causing the valve to oscillate a little, and making it tap against mounting bracket... My best guess...
My Cars: 1974 RX4 Coupe 1991 FC3S RX7 - Sold 2003 ZZW30 MR2 (Rotary swap after RX8) 2004 SE3P RX8 (20B Swap in the works) |
#33 |
Silly question, will they have parking for the rig?
My deuce |
#34 |
Rep Power: 22 ![]() |
Yes, and no. There should be a place across the street from the lodge to park it, but when the show is on the space will be tight. There are other spots to park though, and many cabins might have room.
#35 |
1. Change wheels/pads
2. Adjust the SC belt 3. Fix a pesky coolant leak (only high rpms) 4. Tack my wheel weld and bumper up with something more presentable than racing tape ![]() 5. Swap fluids 6. Try not to crash on track before the event
2006 Two-toned RX-8 2005 SC'd street-ported RX-8 |
#36 |
Mountain Man
Install new oil cooler lines
Add oil Get all 4 wheels back on the ground Pray it still runs in April... Pretty intense.
-'93 BB Touring- Garage ornament -Had: 87 SE, 86 GXL, 91 'Vert, 85 GS, 87 GXL, 88 'Vert, 86 Sport, 89 GTU, 85 GSL-SE
#37 |
-Alignment
-New brake pads -Decide to tune as is, or go ahead and install BNR Stage 4 (would need an intercooler solution, Rotary Extreme V-Mount preferably) -Decide whether or not to purchase AEM Water/Meth kit for water injection -Find and fix small exhaust leak -Plan new oil cooler setup (I want a dual set similar to the FD) -Complete parallel fueling setup -Get rid of crappy Prosport Evos the car came with and install AEM UEGO gauges -Make sure that my other engine is still all ready to go incase I blow the current one up before/during DGRR haha Last edited by Daedalus704; 03-18-2013 at 01:38 PM. |
#38 |
I SEE DEAD PEOPLE
Tow vehicle for track car:
Change oil (diesel) Rotate tires Track car: Change oil (still has break-in oil) New R compound tires Fuel up fuel cell Spark plugs Seat harness (expired last year :-( Go-pro roll bar mount Re-do alignment RX-8... Cousin is driving it there: Change a Nissan guy into rotaries Change oil.
VIN-AUTO Rotary list of Fails below: 86 mazda rx7 csp 61 N/A= because RACECAR 87 mazda rx7 t2 with 13b-re cosmo GT42= FKN RUNS!!! 03 Dodge Viper SRT-10 Vert 06 dodge ram 2500 Megacab turbo Cummins=puller 16 MB ML350 |
#39 |
Well, since I found some rust that really needs attention on the Cosmo, I'm bringing the RX-8.
-Change oil -New plugs, wires, coils, -New tires -DETAIL (needs it bad) No biggie.
#40 |
BOILED PEANUTS!!!
Replace the clutch (happening next saturday)
Fix exhaust (hopefully)
![]() www.rotarycarclub.com "The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot." |
#41 |
Got new tires. So that's done.
#42 |
Brake, Turn, Go! Repeat.
Rep Power: 17 ![]() |
1. Install Mazdaspeed exhaust
2. Install clear corners 3. Install super secret, ultra stealth modification 4. Wash, wax, detail
Redhawk |
#43 |
Bubble Tech
ohhh what a fun thread.. ill bite...
Interior Fabricate -dash -floor pans -trans tunnel -pass side seat rail/install recaro seat paint/powdercoat roll bar paint interior oh i should also probably make myself a set of door panels.. Engine bay respray -re powdercoat everything engine bay cover oil cooler swap oil feed line to turbo new VMIC? (may put on hold until i modify new front bumper) Exterior Fabricate -Front fenders/make mold, cast new fenders (nightmare) -Rear over fenders Side skirts/ vents/ canards Spoiler new decals for rims roof rack cargo box paint car????.............. along with some other rubbish.. This is going to be a fun 3 weeks....... ![]() ![]()
#44 | |
Professional Stick Poker
You're an even bigger masochist than I am.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 Last edited by GySgtFrank; 03-26-2013 at 10:03 PM. |
#45 |
Rep Power: 10 ![]() |
Speaking of.... off the interwebs and back into the garage for you!!!!! I wanna see this FB damnit (and I can't believe I just said that) as I'm quite impressed with the work done so far....
List for the 8 hasn't changed... Finish Exhaust Finish stereo Adjust rearview Camer Auto-Close sunroof ReTint the entire car... this entails dropping it off and opening my wallet... I don't have the patience for that Plugs, wires, clean air filter Replace OMP Change oil And detailing it List for the Jeep Install Battery Change Oil I <3 my Mopars
