Professional Stick Poker
Here's the latest little bit. Firstly I finally got the panhard bar axle mount located, modified, and welded in. I had to narrow the G Force mount a little to accomodate my new shock locations and integrate it with my new inside lower control arm mounting tab. Trying to locate (and hold) the mount in the proper plane for 3 different axes was a pain, got it done though.
![]() panhard bar axle mount by GySgtFrank, on Flickr Next came the new lower control arms for the axle. I only have the driver's side done for now, starting on the passenger side in AM. Used the Maximum Motorsports extreme duty arms for the Fox body Mustang. They have a captured Heim style joint and should eliminate the bind from the stock rubber bushed arms without being a noise monster like normal Heim joints. ![]() lower control arm - front mount by GySgtFrank, on Flickr ![]() lower control arm - rear mount by GySgtFrank, on Flickr They don't look like much, but they were a pain in the butt to get them in there at the correct angle. Used the stock outside control arm mounting tab on the body and axle so I didn't get them out of alignment. It also makes it easier to get an identical copy on the other side. The arms are quite a bit wider so I had to fabricate the inside mounting tabs on both ends. Once I get the other side done, it's on to figuring out how to get the Maximum Motorsport swaybar mounted. I love a challenge.
