Closed Thread
Old 02-17-2013, 05:49 PM   #1
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
A few more pics from weekend progress, it's a real shocker (sic). Had to notch the wheel well housings and rotate the bottom mounts slightly to angle the shocks inboard.
inside of wheel well
Spring &Shock by GySgtFrank, on Flickr
interior mount.
shock mount by GySgtFrank, on Flickr
on ground at full drop, tires hit sheetmetal slightly.
on ground 2 by GySgtFrank, on Flickr
At desired ride height.
on ground 4 by GySgtFrank, on Flickr
Found that the rear axle was not centered from the factory, offset slightly to the driver's side. Planning on replacing the lower arms with Maximum Motorsports arms that use a captured Heim style joint. Adjustment shouldn't be a big deal with my panhard rod once I get rid of the bind.
Don't look at the puddle of oil under the car. Left the driveshaft out and it emptied from my transmission when I lowered the car back down to the ground.
GySgtFrank is offline
Closed Thread
