the intake temp are from after the intercooler, the stock location of the air temp sensor is under the UIM. some people move it to the throttle body Elbow or after intercooler piping to reduce heat soak numbers, but then require recalibrating in the ECU because of lower intake temp being recorded.
500+ HP thanks to: ![]() Fast reacting IAT sensor thread! Mechanical Pre-turbo Water Injection Thread Dual Stock fuel pumps Thread T2 differential swap! |
