#1 | |
Don Mega
The 10 and 11 heat range plugs work totally fine in those conditions, you just need a properly calibrated engine map that is set to work in all operating conditions. With a proper CDI ignition system (leave inductive for the chumps of the world!) there is never any need to worry about the garbage of a warm up then race plug, that is plain idiotic.
Sounds good!
Sent you PM earlier btw, not sure if you saw that. Was very OT so figured it was better to send it privately
