| Piston Engine Conversion Have you replaced your rotary with a V8 or any other type of piston engine? Tell us about it! |
Rep Power: 22 ![]() |
Sooooo....it isn't broken?
DGRR???
nerd
Rep Power: 15 ![]() |
its on probabtion, the noise is still there, neither myself or my friends have been able to pin down the source...so for lack of desire to describe it in text...im going to run it till it pukes or it doesnt and then ill know.
as for DGRR, its still planned if the car behaves, although now i need to touch up paint the damages and find a new bumper which is difficult around here, finding one as perfect as mine...was...is nearly impossible, but considering the circumstances im sure the knowing eyes of the DGRR folks will know why my car isnt as clean and perfect as it should have been upon arrival to the show... i have a BAD vibration in the driveline, im almost positive something is amiss with the driveshaft the was altered to fit the new configuration, so i have to take that back to the driveshaft shop and see whats what. anything above 60mph tried to shake the car apart, while we were out playing with the car in "mexico" i had the car up to some northern speeds and the vibration is terrible and unsafe so im taking it back apart and fixing some of the damages from the impact while im at it. i have my 3.08 gears for it...they came in the day of the wreck...dammit...it needs those bad...as you can see...it spins a bit
nerd
well i have another issue not related to the impact or engine noise..
along the way in this build i overlooked something very important...and when i say overlooked, i was aware of it, i just kept it on the back burner....well it bit me... i have a bad trans/driveshaft/pinion alignment problem...and there isnt much i can do about it easily. the transmission ended up a little lower in the car than it was, and possibly at a different angle(i dont have another 7 around to measure), also...im not sure my grannies 8.8 is at the right pinion angle to start with...ill verify that when i can pin down the info i need to do so.... this results in the pinion being about 4 deg north of the trans angle, and almost directly in line with it......it caused an immediate failure of the yoke Ujoint within the 140miles i put on it so i put it on stands to investigate the vibration and discovered my oversight....but an oversight i couldnt really avoid...due to space constraints SO i needed to change the rear end gears anyway, so it needs to come out now to investigate further my problem....and time is running out for DGRR...and money ran out a long time ago... ![]() im probably going to have to build a 2 piece driveshaft or something...i cant really move anything around in any direction... |
