Old 01-29-2013, 09:44 AM   #1
FRA-497104 *3 for the AST
SUM-220071 *1 for the rad
SUM-2200075B *1 for the return line in the tank (used from my personal stash)
and then the -4 fittings needed for the line from the rad to the AST, I'm thinking a straight on the rad, and a 90* on the AST given where it's being welded
grumble grumble Crutchfield grumble grumble Norm
Old 01-29-2013, 12:16 PM   #2
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
and then the -4 fittings needed for the line from the rad to the AST, I'm thinking a straight on the rad, and a 90* on the AST given where it's being welded.
Ok, so I'm looking at the stuff on Summit right now, why the SUM-220071 on the radiator? Wouldn't it make more sense to have a male bung welded on? That way we could just use a standard -4 AN hose end..
Also, I had originally ordered 2x of the FRA-497104's, they came in the same box as the rest of the -4 stuff. I'll double check in the boxes downstairs to be sure we didn't accidentally overlook them.
And I'm kinda thinking of just going ahead and -16ing the radiator right now, as the shop will already be welding on it... If I do that than I think I'll make two separate orders, one for coming here, and one going there.
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-29-2013, 12:38 PM   #3
Because it make pressure testing the rad that much easier.
Did not see anywhere
If you're gonna do that, you're also going to need the -16 AN fittings welded onto waterpump housing as well. And if you're going that far, you might as well get rid of the T-stat housing and build a combo t-stat housing/ AST tank as opposed to the hooky way it's going to be mounted now.
Personally, I would do it that way..... oh wait... I am doing it that way on the 'vert I would've done it that way on the FC but didnt' really have the room because VMIC.
Old 01-29-2013, 08:52 PM   #4
I've seen you fit more in less space
