#16 | |
Thanks Robert, for the comment and the deal on the carb hat!!!!! I have to agree this one is looking alot sexier than my last build. Few pics of what I have gotten done. But actual work has been taking alot of my time this week. I started on building the exhaust, but I only had the turbo losely attached for mocking up everything else. I had to tighten it up and instead of doing it twice I figured I should finish the oil return and the braided lines. Then I could just tighten it up and consider that part of the build finished. |
#17 |
What have you done for the carb and how much boost do you plan to run on it?
I actually have the 13BT IDA manifold and top hat which I acquired years ago while doing an ITB setup and have been thinking about throwing some 48IDAs on it and dropping the setup into a first gen with a stock turbo but I'm still a bit unclear on webers since my carb experience is limited. |
#18 | |
I ran 8lbs normal, 10lbs racing on my last setup and plan the same for This one. |
#19 |
Where did you get the floats?
Nice build BTW 8lbs is the most I think I'd run with my setup.... still thinking about doing it...
#20 |
#21 |
Got ya - thanks...
#22 |
Got some work done last night. Exhaust is almost complete, 4 more welds and add hangers.
#23 |
member
the exhaust looks great. how many pre mufflers are you running? it looks like there might be two in the picks.
leaving my carbon footprint....one start up at a time |
#24 | |
![]() I got the muffler and pre muffler from Parts Off in japan for 8000 yen. about 100.00 It's a Tanabe Hyper Medalion exhaust system for a Nissan Cedric. The Japanese stainless was 3" inside diameter and the stateside stainless mandrel bends are 3" outside diameter. So a chop saw and a tig welder its now for a 1st gen 12at RX7. |
#25 |
exhaust came out great!
![]() ![]() ![]() rotaryshack.com |
#26 |
thanks Robert
I have been waiting on parts for the engine bay so I started working on the interior. When I got this shell the interior tar sound deadening had been removed. The only things inside the car were the dash, center console and the steering wheel. I started with the seats. I had to modify a bride FC seat rail to work under my recaro seats. Installed the rotaryshack short shifter and the Nardi steering wheel. the 4 point roll bar is a tight fit. test fitted the pioneer DVD headunit. Since there is no space left in the engine bay I moved the battery to behind the passenger seat. Need a few grommets to complete that project. |
#27 |
the man
love the work man good job
#28 |
Updated. Wire harness tucked in the fender
#29 |
one Apex @ a time
Thats pretty cool I have the same exact seats I bought off a old co worker for 20 bucks! Yours are in much better shape though..I still cant find what the came out of maybe a trans-am?
1983 Limited Edition SOLD 1977 Mazda REPU I will work on it one day I sware!! 1987 T2 um after the repu is done?? ![]() 2013 Chrysler 200 DD 2009 Dodge Journey 94 Volvo 850 N/A The slowest car I have EVER owned!!! |
