#1 | ||
![]() ![]() The red arrows goes to the two, obvious cracks. Most of the time, you just worry about the cracks. It looks like in your case, the entire area between the two cracks has shifted. Encircled in red... This would explain the soot marks on the gasket. To fix this case, you'd need to first weld the cracks and then machine down the flange flat. Unless you've got the resources to do this, it's way too much trouble. Small exhaust leaks start out as ticking sounds... As they get worst, they progress to a pfft...pfft...pfft and sometimes whistling sounds like old-school VW engines. Quote:
The consensus on these turbo exhaust manifolds is that you either got a good one or you don't. Many of them warp - due to the metal content. Some of them warp (and crack) to the point where they are junk. It's usually easier and cheaper just to replace. -Ted |
