Old 12-17-2012, 07:13 AM   #11
I've got just under 4000 dollars into the total project so far (including purchasing the car). It's more than the car's really worth, but you can spend a lot more trying to keep yourself amused. I'm learning a lot in the process and just having fun. It'll be even more fun when I can get to some of the events and meet some of you in person. Thanks for all the help guys.
Thanks beefhole. It's one of those projects that kind of got away from me. I was going to only put in the 13B and run a carburetor, but I had all the EFI stuff and figured Why Not?
A project that got otu of hand? Say it isn't so!!!!! That NEVER happens....
At that point I can start playing with the engine. I want to avoid any more long downtimes on this project if I can, the car's just too much fun to drive to let it sit again.
Don't you guys have winters? That's when I try to keep all my playing to..... wintertime when I can't/don't want to drive the cars anyway.... Gotta finish my Jeeps and get the 8 off the rd in the next week or so
I found the brake problem. The rear wheel cylinders were shot, that'll happen when the car sits 10-20 years. Tried to make a run to Kansas City to deliver some parts and make a meet the KC guys were having. Burned up a relay about 100 miles out, bypassed it and it was fine. Again, my overly complicated wiring scheme bites me in the a@@. Then about 150 miles out the car starts to sputter and died on the side of the interstate. Do a bunch of checks, no fuel to the filter. I assume the fuel pump went as the fuel gauge was above empty and called some local friends to come help. Put gas in it and it fired right up. I evidently bumped the needle putting in the panel and didn't notice it. Needless to say I didn't make KC in time for the meet. Oh well, this is why I was making the run in the first place. Need to make sure all the problems are worked out before I get too far away.
Shakedowns! Gotta love 'em.... the wierdest shit pops up on them...
but the front 13" discs will take a little thinking on. We'll see.
Yeah.... it's know as 17" rims
For those still interested and in keeping with my penchant for doing things the hard way. (Don't try this at home kids, I'm a Prof-*er*-masochist). Getting the spring buckets and adjusters in car. Had to raise the spring mounting point ala FC & FD. Final placement on the spring perch is about 4 inches higher than original. Need to be able to lower it without going to ridiculously stiff springs. Used adjusters so I can alter ride height and weight jack for suspension tuning. Guess what? 5" diameter springs don't quite fit between the frame rail and wheel opening, such a surprise . Now know why Mazda used those oddball diameter springs. Had to notch the frame rails as I didn't want to take up any valuable tire space in the wheel wells.
Spring opening by GySgtFrank, on Flickr
spring opening 4 by GySgtFrank, on Flickr
spring opening 2 by GySgtFrank, on Flickr
spring perch w_adjuster by GySgtFrank, on Flickr
spring on perch - new by GySgtFrank, on Flickr
Just have to get it closed up and the final welds done, then onto the other side. Back to work...
That's really fucking cool and impressive at the same time.... I approve of that way of doing things
TitaniumTT is offline
