Old 05-05-2008, 11:10 PM   #4
dudemaaan
dudemaaan's Avatar
something between the emanage system and the PFC i honestly am not entirely sure how i fixed it. i just got under there with a flashlight and pulled some wires apart and hooked it up the way i knew to be correct and it worked. I had noticed that the emanage was displaying the correct map sensor voltage as well so i knew the wiring had to be correct at least somewhere close to the ECU. I studied a few different wire diagrams and wrote down what color wires were input and output and then it was rather simple. Thanks for the reply
