Old 09-30-2012, 03:10 AM   #1
85turbo12a
nerd
85turbo12a's Avatar
85turbo12a is on a distinguished road
here is the transmission on the engine, i had to adapt a camry 1mzfe starter to fit the mazda bellhousing, i cant find a pic of it right now...its not super complicated though, its a gear reduced starter, the T2 started lacks the nuts for a v8.
here is the shifter relocation mod i had to do to move the engine back 4 inches and retain stock interior, only permanent mod to the trans itself was i had to cut off one ear of the original shifter housing boss on the tailhousing.
85turbo12a is offline   Reply With Quote
Old 09-30-2012, 03:16 AM   #2
85turbo12a
nerd
85turbo12a's Avatar
offset bushings i made for the rack to lower it as much as possible
front view with mock engine in final location
more to come...
Old 10-03-2012, 10:53 PM   #3
85turbo12a
nerd
85turbo12a's Avatar
timing belt installed, working on the new belt tensioning system, and making it all pretty, incidently strips of velcro mimic a serpentine belt pretty good for figuring out what you are going to do and how long the belt is going to be.
i have to dissect the stock spring tensioner...looks like that might be a dangerously amusing good time, then will mod/fab/machine accordingly and then i can put the darn thing in the car!!! then plumbing...yay....
