RX-7 3rd Gen Specific (1993-2002) RX-7 1993-2002 Discussion including performance modifications and Technical Support Sections. |
Rep Power: 10 ![]() |
I took my a/c out because I personally don't like a/c, it doesn't get hot enough out here, and it's a great weight savings
I took my p/s out because I overworked he pump in an autox and it locked on me, plus the manula rack has a solid quill to it, but before when I properly depowered my powersteering rack, I welded the quill solid and got a lot better road feel 1st gen abs systems like the ones found in the RX's are horrible. Plus I put on a custom set of 12.2x1 rotors Wilwood calis in the REAR, and 13.25x1.25 rotors and 6 piston calis in the front. Soooooo are you doing it for weight savings like the a/c system? Or for better road feel like removing the p/s and ABS systems? Explain to me how removing the IAC is anything like those. Just say no to removing IAC.
Rep Power: 14 ![]() |
I'm deleting it to clean up the engine bay. And like I said if it causes problems I have 0 issues re-installing it. I'd like to try it without first though.
Regardless, any input on grounding or fuel temp sensor deletion?
Bookmarks |
