Old 09-04-2012, 11:44 AM   #1
730RWHP12A
Originally Posted by mattallac View Post
the turbo is a t3/t4 we are only gonna run 5 to 7 psi on an na motor . you know about what to do for the distributor ? Q- drill out the acc pump :how ?
the distributor needs to be locked so the timing does not advance 30 degrees when your making boost. the timing should be set at 15 degrees advance total, more boost, less timing..
to drill out the accel squirter remove it and use a jet drill set to enlarge the holes. i will measure the one i use an get back to you ...
rotaryshack.com
Old 09-04-2012, 10:56 PM   #2
mattallac
mattallac's Avatar
mattallac is on a distinguished road
cool thanks
mattallac is offline   Reply With Quote
Old 09-07-2012, 12:31 AM   #3
mattallac
mattallac's Avatar
well the distributer is done now i have the carb open looks like 3 jets per bank , so drill the jets that are in line with the squirter correct? leave the other jets alone ?
Old 11-13-2015, 09:12 PM   #4
Derbot24
Derbot24 is on a distinguished road
I am also looking to find out what I need to make it a blow through carb.
Derbot24 is offline   Reply With Quote
