I made a set of studs for myself some years ago and felt that the pan was harder to fit over the studs because of the manufactures tolerances .The brace was a bit hard to slip over the studs as well .Some people will not deal with this .With the bolts the install is as easy as 1-2-3 .The bolts for the pan and motormounts are 10.9 which are higher grade than the studs I had found.I send 19 pan bolts so with later age pans you can drill the two marked holes under the motormounts in the pan ( the block is threaded already ) and grind ,drill the clearance for the bolt head in the motormount . for even better sealing .If you like studs better that is fine as well,I just tried to make this easy for those who are not as mechanical as some of us .
