Whatever is cheapest of the name brands minus the generic crap like the WalMart house brand...
Right now that's Pennzoil from KMart @ $22 / gallon. With the prices all over $5 / quart, it's getting expensive! I used to love the good 'ole days when this stuff was under $3 / quart. ![]() -Ted |
#2 | |
Rep Power: 14 ![]() |
is it any different from others?
and how much does everyone add per gallon of gas? |
I was using Valvoline Multi-Use exclusively, until it started to climb over $6 / quart.
We've used Castro too with good results. As long as it has the TC-W3 rating, it's good to go. Yeah, the viscosity is a little different between the brands, but our teardowns show good wear. We've run race motors (NA) with mostly Valvoline Multi-Use upping the ratio to 50:1 - 75:1 with good teardowns. I normally just add half a quart (16 oz.) to a fill-up - 1987 Turbo II - which normally comes out to about 12 - 13 gallons, and the ratio comes out to right about 100:1. For S5's with the bigger fuel tanks, if you do this, the ratio comes to just about 120:1 - 130:1. -Ted |
#4 | |
ok cool and sounds good, last question, since my oil metering pump is deleted, can i use start using synthetic? |
Rep Power: 20 ![]() |
I mix cheapo Wal Mart TCW3 oil in my non injected motor, I also use synthetic motor oil.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
Castrol SYNTEC 10W-40
#8 | |
-Ted |
#9 |
idahorotary.com
Klotz Benol Castor Oil
87 TII-E85-600+ RWHP and climbing Life starts at 2 bar! Come visit my forum! idahorotary.com http://idahorotary.com/smf/index.php |
Bookmarks |
