Old 06-06-2012, 10:42 AM   #11
infernosg
IT'S ALIVE!
infernosg's Avatar
Originally Posted by beefhole View Post
Use the location the stock computer (once) used. Where you have it should work as long as it doesn't interfere with the thermostat.
That's where I have it now - in the thermostat housing. It's the sensor in the foreground. The second sensor is for an independent water temperature gauge. The problem I have is my TPS connector is pointing straight at it so clearance is going to be tight.
infernosg is offline
