#1 | |
Rep Power: 20 ![]() |
Also, apparently the flex fuel sensor modulates the frequency and pulse width of the output to represent the ethanol content so I would need the Zeitronix (or some other) interpreter to change it to 0-5v output.
#2 | |
The trim on the e6k looks for 2.5v. Anything over increases whatever setting up and below goes down. I would only use it for adjusting for e85 vs e70 or what not. Going from e85 to pump would definitely require a different map.
#4 | |
Also, I have very recent study which examines effective octane number of ethanol and several blends with gasoline. What is awesome about this study is the fact, that it separates effects of evaporative cooling from true, so called effective octane, which is based purely on chemical antiknock properties of given fuel. Simply said, ethanol-gasoline blends, even with very low octane gasoline as base, have peak chemical knock resistance at about 50% volumetric ethanol content and any more ethanol content just increases cooling effect. This brings another phenomena, for given air temperature, lower ethanol content fuel realizes more of theoretical charge cooling effect and vica versa. So effectively, as far as knock resistance goes, E85 is no better than E70 or E50, unless the intake temperatures are over 100°C. |
