Here's the Pics.
Even though the wiring colors are different, the S1 (79-80) and S2 (81-83) switches operate the same, and can even swap side-to-side. After cleaning the contacts and re-soldering I got the pair of S1 switches to work in my 83. They do have a slightly different look to the actual rocker, not enough to notice until you have one of one and one of the other. ![]() The first 2 pics are the S1 switch from the top, and then from the bottom to match my diagram. The last 3 are the S3 switch assembly. Notice that the wiring for both switched combines into the one 6-pin harness. So if you have one switch go out (and don't want to do the old snip-and-solder to the wires) you have to replace the whole unit.
Michael Pinto 2008 PDXCGP Drag Racing Season Champion 83 RX-7 GSL; 12A/5-Speed, Red/Red; 100% Stock - 16.072@83.39 01 CV Police Interceptor; 4.6 SOHC V8/4R70W, Dk Blue/Grey; K&N FIPK/RP Oil/Optima/Superchips/Flowmaster 40's/2.5" cat-back - 14.854@92.37 Read my Rx-7 Build Thread! http://rotarycarclub.com/rotary_foru...ed=1#post70955 Get on the new RCC 1/4 Mile ET List! http://www.rotarycarclub.com/rotary_...read.php?t=368 Vote for the ROTM! http://rotarycarclub.com/rotary_foru...play.php?f=125 |
