Old 04-18-2012, 10:44 AM   #1
magpiemini
magpiemini's Avatar
magpiemini is on a distinguished road
If it stock carb, it's a 12A.
13B's are only available in the top-of-the-line GSL-SE's with stock fuel injection.
GSL-SE = 4x114.3mm bolt pattern hubs, rear disc brakes
Everything else = 4x110mm bolt pattern hubs-Ted
I admit I am new to this rotary stuff but I have seen 13b engines with carbs, were they not delivered that way from the factory?
1984 RX7 GSL-SE
Building for the 24 Hours Of Lemons
magpiemini is offline   Reply With Quote
Old 04-18-2012, 12:07 PM   #2
Not in an rx-7. early and mid 70s rotaries had carb'd 4port 13Bs... but all 1st gens were either carb'd 12As or fuel injected 13Bs.
Old 04-24-2012, 11:37 PM   #3
j9fd3s
1. i would look in the factory parts catalog for jetting before sterlings website, his chart might not be accurate.
2. an 85 GS should have a 12A in it. there are a couple flavors of 12A, but a 4 belt pulley and studs on the front cover probably mean the engine is the correct one.
3. there is a page in the factory shop manual, www.foxed.ca on how to do a tuneup, like setting the idle mixture and timing, you should start there.
