Old 04-16-2012, 10:05 AM   #2
Raksj04
I have Ultra power in me.
Raksj04's Avatar
Originally Posted by T2Mouse View Post
Hey guys, i recently purchased a s4 t2 rx7 and the other day while driving the car died on me and wouldn't start again. I traced what i think the problem to be down to the fuel pump not turning on i looked at the factory service manual and have been going through the relays and air flow meter trying to get it to work again. I jumped power straight to the pump and it turned on no problem and i thought that the car should be able to start but it still wouldn't start. I then read that the rx7 fuel pump doesnt come on when the key is turned to on, only when the car is cranked and the afm see's a small amount of air going to it. now because jumping power straight to the pump and having it still not work i feel it must be something else. would a bad afm cause the car to not start at all with the fuel pump jumped on? It is possible that i am with out spark, could someone please tell me how to test for spark?
like you do on a lawn mower. pull the EGI fuse and check it. pull it out and put it against the block had a buddy crank it over. if you hold onto the plug you have the potential of getting shocked. check all four spark plugs. If that EGI fuse, under the hood fuse box, is blown you will not get fuel to the engine. You pull it and crank the motor over as part of the deflooding procedure.
