| View Poll Results: What oiling setup to use for racing | |||
| Leave it stock and run the right engine oil |
0 | 0% |
| Leave it stock and add some pre-mix |
8 | 53.33% |
| Disable the metering pump and pre-mix |
6 | 40.00% |
| Other - I have posted a better idea |
1 | 6.67% |
| Voters: 15. You may not vote on this poll | |||
Cheap TCW3 from the parts store. I think I'm currently using Marine grade (whatever the difference may be to others). Mix it 1oz/gal and the car is happy with it. Doesn't hurt the wallet much and I know it's mixing with clean oil. Although it's a fresh rebuild so the oil has been staying clean for a while, but it won't always be that way.
