Closed Thread
Old 04-03-2012, 09:47 PM   #1
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
killing bugs
Been trying to figure out my headlight motor problem. They go up and down on their own now and then. Sometimes the passenger side, sometimes the drivers, sometimes both. Even more annoying is when both the up and down circuits are powered and they keep cycling up and down continuously going down the road. Just call me Winky. I think the problem is in my combination switch. It fell apart on me when I was trying to trace wires. I thought I had it back together right, but it has been giving me problems with a few different bugs.
I did get the extra muffler mounts welded in. The muffler shop said I didn't need them, but too much vibration in that tight of a space. The mufflers need to be supported on both ends.
Build23. by GySgtFrank, on Flickr
Still working on the front subframe. Finally got the rusted together struts apart. I had to run a heavy bead with the MIG on the old strut shaft to get something to hold them while I fought the top bolt off (they just kept spinning). I think it needed new struts anyway.
Build24 by GySgtFrank, on Flickr
The good is that I have a new brake master cylinder on the way from MazdaTrix, inside door latch cups from Atkins, and a used combination switch from Frodogray on Ebay. We'll see if these help.
It looks like the guys in KC, will?, be having a get together on the 15th and I want to make it over there for that. It should be a good shakedown cruise.
GySgtFrank is offline
Closed Thread
