Old 03-20-2012, 08:59 AM   #1
fc nut
member
fc nut is on a distinguished road
thanks a lot, I'll check it today. one of my problems is the ecu harness. mice made a nest under the foot panel and chewed on the harness. I checked the ecu and the relay ports didn't read 12v,it was .5v. I'm replacing the ecu as well, just in case the wires shorted it out.
leaving my carbon footprint....one start up at a time
fc nut is offline   Reply With Quote
Old 04-15-2012, 08:50 PM   #2
fc nut
member
my se is on the road now. I washed it and took it for a drive tonight. on its maiden test drive I had a civic wanting to race. se 1 civic 0. oh, it was a newer si. anyway, it ran great. it needs some things done before its 100% ready for a spirited drive. here's some car wash pics.
Old 01-01-2013, 08:49 PM   #3
fc nut
member
i haven't updated in a while. i didn't post any pics of the car during the install of the s4 engine. i'll explain each pic as best i can about the swap.since i finished the swap,i've been working on getting the interior together and just driving the car.it's present state is,i need to replace the master cylinder and replace the coolant seals in the engine. i have a 12a trans in the car and let me say this ...... it runs like a raped ape.
this is the mods that needed to be done to the s4 intake.i had to block off the secondary injector ports with quicksteel.
the s4 engine ready for the se's pickup tube and pan.
the engine with the pan,s4 water pump housing ,pump etc. installed
throttle body with the cold start removed
pulsation dampner delete
engine installed with emissions deleted
the exhaust i made for my car
