Old 04-16-2008, 02:50 PM   #1
By the way, the 24V thing at DGRR wasn't true...
Later that night, I couldn't believe that the alternator was producing that kind of volt so I decided to check another FE... Sure enough, the other FE was producing the same voltage. I then guessed that the volt meter was off.. Next day volt meter was tested and sure enough, it was bad.
My volt meter suggest that the car is producing enough voltage.. My guess now is that 8 is sucking up power and when voltage drops its putting the car in the limp mode (my previous problem). My current problem, I'm guessing maybe the ECU had to learn?? I'm just keep an eye out and see... I guess if I make it hope ok, then I'm good.
Oh, does anyone have any info about changing out Fuel Filters?? I'm just going to go ahead and do that just in case..
Old 04-16-2008, 03:11 PM   #2
fikren
fikren's Avatar
fikren is on a distinguished road
ah ok, I never heard the update that it wasn't pumping out 24v.
Fuel filter is not replaceable without replacing the entire pump as it is integrated into it. If I am not mistaken, the access hole is under the rear seats so you have to lift them up. From what I have read it is essentially just pulling up on the seats and there should be four screws then.
Mazda claims the fuel filter in their pump is good for 100k miles but who knows.
I think mazsport makes a true bolt in replacement pump which may also flow more but I have not really looked into it so I do not know if their filter is replaceable or if its like OEM where the whole pump has to be changed with it.
93 bb rx7
Destined to be the never ending project car or possible part source for the rotary rat rod
2008 40th Anniversary Edition RX-8 - bankruptcy owned me
RE-Amemiya Super Dolphin Tail Exhaust-for sale
AutoExe Front and Rear Strut Bars-for sale
AutoExe Member Brace Set-for sale
2008 Honda CBR600RR - bankruptcy owned me
Motivation axle/fork/barend/frame sliders
ASV "unbreakable" shorty levers
Tripage Integrated Tailight and Adj FE
Proton Fushmounts
Akrapovic Hex Carbon/TI Slip On
Sato Rearsets
fikren is offline   Reply With Quote
