Old 04-16-2008, 10:02 AM   #1
Yesterday, I took off from work early and did some testing and checking..
All the connection seems to be ok and I also checked the VFAD. Everything seems to be OK.
So, I started the car and the car started and died as the idle came back down. So, I started up again and kept the RPM up and it stayed alive.. I kept the idle up for about 30 secs and it idled back down..
I then shut the car off and did the ecu reset. I started the car and it started fine and idled perfect!!
So, this is where I stand today..
This morning... I started the car, it started, and died as RPM went from 3k to 1k.. and dead.
I started the car again and it started fine!!! I drove it to work and everything seemed ok..
I just don't understand??
PHIL
