Old 01-02-2012, 03:29 PM   #1
RICE RACING
Don Mega
RICE RACING's Avatar
Originally Posted by just startn View Post
Rice- were do you order your molykote from?
My local parts shop keeps Valve and O'Ring lube 111 at my request, that and 3 Bond 1215.
Ring Dow Corning (they are the makers and inventors of Silicone and they run the Molykote brand) they will tell you a local stockist to you
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-03-2012, 11:41 AM   #2
just startn
Turbo Vert
just startn is on a distinguished road
Like this. Labeled Dow right on it
http://www.ebay.com/itm/DOW-CORNING-...item35b79223d2
or like this (as seen kinda in your posted picture
http://www.ebay.com/itm/MOLYKOTE-111...25936648678546
Before i went ahead and called them i wanted to do a little research on it ect.. It seems theres many different types:
I came along this website--http://www.ellsworth.com/molykote.html?gclid=CMj0uPChtK0CFUgRNAodP2UYnA
As a result i see this:
Dow Corning® 3452 Chemical Resistant Valve Lubricant
Dow Corning® 3452 Chemical Resistant Bearing Grease is chemically resistant; has a good load carrying ability, effective in high temperatures and is compatible with most gaskets, seals and packings. 57 gram tube.
Dow Corning® 55 O-Ring Lubricant
Dow Corning® 55 O-Ring Lubricant is a soft silicone-based grease, slightly swells rubber for better sealing, oxidation resistant and serviceable over a wide temperature range. 150 gram tube.
I do not see numbers "111" on any product they sell so my assumption is the above products i have pasted from the link are not at all what were looking for. I have tried to find a place that stocks Molykote here in the US but so far im not coming across anything. I may just have to call.
just startn is offline   Reply With Quote
Old 01-03-2012, 03:24 PM   #3
RICE RACING
Don Mega
Wink
^ Yep either one of those on E-Bay is it, just different packaging for their markets (same product).
The others you quoted I have in my Molykote Engineering book at work, I don't recommend you use them as I can't verify how good they are in our applications.... the V&O lube 111 is tested and works
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-03-2012, 05:02 PM   #4
just startn
Turbo Vert
I orderd the First one out of the 2 ebay links i posted & grabbed another tube of hondabond. Will recite this thread when i use the product.
