On a stock port 12a, I went with a lightweight steel flywheel. I based this on forum input that a very light flywheel would be difficult to use on a daily driver.
Based on the difference between the stock flywheel and the light steel, I now wish that I had gone with the aluminum. How that applies to a turbo, I can't tell you. Good luck. ![]() .
Rep Power: 15 ![]() |
The faster you can rev, the faster you'll get on the boost.
Ryan |
