|  12-06-2011, 11:40 AM | #1 |
| Sigh..... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 20  |
				Oil Filter Pedestal Recommendation
			I'm looking at picking up an oil filter pedestal for my 6 port turbo build.  I need to run a T4 feed line from there to my turbo.  The only three I've found thus far are Racing Beat, Respeed, and the Prosport sandwich.  The T4 feed lines I've found run a 1/8NPT which all of the pedestals have.  From the cost it seems like the Prosport is the way to go ($35 cheaper) but I'm wondering if anyone has experience with these and has a suggestion.  I don't mind spending the extra money if it's worth it, but if the Prosport will work just fine then it seems like a good choice.
				__________________ 1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present." |
|  12-06-2011, 12:13 PM | #2 |
| Lifetime Rotorhead Join Date: Apr 2010 Location: Elkton, MD
				Rep Power: 16  |
			I don't have experience with any of these brands, but am using one made by the old FC3S.org store that is basically a clone of the RB & RESPEED designs. I'm using it for oil pressure & temp gauges only, and it works well. These designs, replace the stock filter pedestal completely. Since the Prosport design does not replace the stock pedestal, and just screws down on top of it like a regular filter, I see a couple of potential issues to consider: 1. On the Prosport, your filter will sit up a bit taller than the others, which may create an interference issue for you - especially at oil change time. To figure worst case, add the thickness of the Prosport adapter to the top of your filter, and take a look to see if it will get in the way of anything. Take into consideration the room needed to R&R the filter in practice. 2. Since the Prosport screws on just like a filter, it is possible that the ports won't be lined up exactly where you need them to be when the Prosport adapter bottoms out & seals up to the stock pedestal. Only way you'll be able to find out for certain is by test fitting it. |
|  12-06-2011, 12:38 PM | #3 |
| My minds tellin' me no... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 22  |
			I have the RE-Speed Version 2.  I haven't installed it yet, but it is a VERY nice piece!
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
|  12-06-2011, 01:02 PM | #4 |
				Rep Power: 20  |
			Does it come with a block for the unused port?
|  12-06-2011, 01:11 PM | #5 |
				Rep Power: 22  |
			Negative.  But you can pick that up for a few cents at any parts store.
|  12-06-2011, 01:13 PM | #6 |
| RCC Contributor Join Date: Mar 2008
				Rep Power: 18  |
			I have the prosport one im gonna use it for oil pressure. If you wanna use as a tester let me know
				__________________  85 rx7 gsl-se - AA tags/ never ending project will never run |
|  12-06-2011, 01:47 PM | #7 |
				Rep Power: 20  |
			Hmmm that would work.
|  12-06-2011, 02:44 PM | #8 |
| Rotary Masochist Join Date: May 2008 Location: Floyds Knobs, IN
				Rep Power: 18  |
			I've used a couple RB pedestals with no issues.  I've used one Prosport and it leaked.  The universal nature of the Prosport looks to cause less than ideal contact with the o-ring that seals it to the stock oil filter pedestal.
				__________________ _______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
|  12-06-2011, 02:46 PM | #9 | |
				Rep Power: 18  |
			I've got the Prosport one.  I had problems with leaking and fitment at first. The fitment problem was the side port bolts that block off the ports. The side one towards the front of the engine was making contact with my fuel line clamp. So as I tightened the adapter down it wanted to spin a little and was pushing my clamp for the fuel line off the hose. I ended up having to turn the adapter so that the two front ports were facing towards the transmission. The leaking I hear is pretty common. It took me a few times of taking it off and putting it on to get a none leaking adapter.
				__________________ Quote:
 1990 Vert/ S5-JDM 13BT (rebuilt but with issues I'm working out). Rtek N370 1.7, 550/800 injectors, FD fuel pump, RB REV TII exhaust, Tein springs and Illuminas | |
|  12-06-2011, 06:57 PM | #10 |
				Rep Power: 20  |
			Sounds like RB or Respeed is the way to go.
|  12-07-2011, 09:47 PM | #11 |
| Fired up! Join Date: Aug 2011 Location: Queens, NY
				Rep Power: 0  |
			one more! http://www.risingrpm.com/products/pr...l_block_a.html the fuel line idea is OK, but sort of unnecessary... I do like some of their other products though... I'm thinking of getting the IAC piece and maybe the TB adapter. |
|  12-08-2011, 01:32 AM | #12 |
| Rotary Fanatic Join Date: Feb 2008 Location: Smyrna, TN
				Rep Power: 18  |
				Bobby
			I got the re-speed one on the truck if you want to take a look at it.   I also have one that came off of deathtrap that u can look at.    I think it might be the RB one.    U know where I am. Where r U. |
|  12-08-2011, 09:03 AM | #13 | |
				Rep Power: 20  | Quote:
 Busy as always.
				__________________ 1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present." | |
