#16 |
Don Mega
No way ever would I use higher than 9.0:1 compression rotors as found in the S5 onwards turbo engines. Do not recommend it for any fuel types in human existence. You will always need to run non ideal fuel mixtures and spark timing and all of these factors point towards the static compression being WAY TOO HIGH.
#17 | ||
Rep Power: 10 ![]() |
![]() Or just drop in some turbo rotors. I'm thinking about putting in a set of the the S4 n/a rotors into the 'vert. But this will be a low boost, stock turbo engine. A little more compression to liven it up down low... but we'll see. Quote:
#18 |
Don Mega
E85 is a total certified nightmare > read here > http://www.ausrotary.com/viewtopic.p...de809551254e98
I convert one car a week back from that bullshit to gasoline and water injection. I am not the only person either, across the country MANY people are doing the same, there are so many horror stories running this hyped up shit its unreal............. most are too ashamed to admit how many engines that they have destroyed as a result of running E85 crap! You need to see what it does to your rotor bearings after it contaminates the sump oil, again something no one will tell you about, but is a well known fact in the "industry" For road cars E85 is a total con job, its really a race fuel and a very poor one at that given how often it fucks engines. I was waring people from the outset of this bullshit being promoted as gods gift, and its turned out to be the BDC of fuels.
#19 |
@ BDC of fuelsThat's something else that I totally forgot about.... what it does to the oil. Obviously not as much of a concern with piston engines but still something to be aware of. It amazes me that you don't really hear too much about the failures of it, just about how great it is before it's even used. I suppose it could have it's place though.
