Old 11-13-2011, 07:29 AM   #1
rgould
Rotary Non-conformist
rgould's Avatar
rgould is on a distinguished road
Be very careful about this...
There is a right way and a wrong way for these coatings.
In general, metal sections are used to conduct heat (away).
Putting coatings on the wrong surfaces can increase (internal) heat (into the cooling and oil systems).
Mazda engineers have documented that the rotary engine oil system takes care of 1/3rd of the heat (dissipation) from the working engine.
I'm running Ceramic coated rotors on the recommendation of my engine building
(Rick Engman)
You should remove the word "internal".
Point taken
It is also not recommended for critical clearanced surfaces.
I was not recommending this surface treatment. Yes it wrecks a finished machinied surface. I have had to remachine shot peeded race piston engine parts it's sucks
rgould is offline   Reply With Quote
Old 11-13-2011, 12:14 PM   #2
kfcpork
kfcpork is on a distinguished road
all very good advice i had forgotten about the fact side plates and what not are machined surfaces much like a crosshatch in a bore of a piston engine. but keep opinions/experiences going this is a food for thought thread so one day noobs like me going threw a first rebuild can see different options and choices and do it right the first time. i've had to fix plenty of mistakes in the subaru game because people don't listen to the simple facts laid in front of them still am atm im welding up a new header for my buddy becuase he thought some cheap chinese copy of a greddy header was just as good as the real thing and after less the a hundred miles the flanges have warped and welds have cracked FML. point of that stroy i guess if give what ever you can so people dont make mistakes like these and give up on rotaries
kfcpork is offline   Reply With Quote
Old 12-06-2011, 06:54 PM   #3
j9fd3s
the coatings are an interesting topic. thru the history of the rotary engines mazda has tried several iterations of coatings on various bits, the ones that offer a good benefit for the cost have made it into production engines.
with the side irons the R100 engine was the first to have iron side housings, and until the end of Rx3/Rx4 production in 1978 the irons are just natural. the finish isn't mirror smooth, its fairly rough, as it needs to hold oil.
with the advent of the Rx7 in 1978, the irons are gas nitrided. this gives the iron that grey color. the nitriding wears much slower than the bare iron something like 10x, and it also reduces friction. Mazda has published info on this, if i run across it, i'll post it up.
the RB26 engine in the 787B uses a ceramic coating, both to reduce wear and probably lower friction. i have no info on this, really.
i know next to nothing about the coatings for bearings, although since a rotary bearing is just a bearing, i don't see why it wouldn't work, as long as you make sure you have the clearance AFTER the coating is done.
rotor face coatings i am undecided about. there actually is some conflicting info on the subject. both NSU and Mazda show that the rotor face temps actually need to be rather hot. as you can see in the attached graph the NON cooled aluminum rotor (something mazda didn't try until the late 80's) actually does not run hot enough.
this may give an opportunity to have fewer losses into the oil, and thus make the engine more efficient, along with loosing the oil cooler. pic #2 is the heat balances of the NSU engines. note the heat into the oil is much less than the Mazda already.
however Ted's point is also valid, the heat has to go somewhere... and the NSU engines have different construction.
mike
