| Fabrication Show off the parts that you've built from scratch or highly modified |
Rep Power: 10 ![]() |
Sadly though, the BBS wheels still wouldn't fit. That last 1/4" of the new hub that protrudes past the spacer is too large to fit inside the hub off the 'vert wheels. It's off by .0150"
Looks like my machinist will have a job 11/7 turning those down ever so slightly... oh well. Regardless, I used the ASA rims that I've been wanting to sell to set up the fenders. The diameter is the same and the offset was off by 2mm, close enough for fenders. So with the fenders mounted and the new rims, I went to go get the trailer inspected.... it failed. Apparently I was short 4 lights..... Damn I hate the DMV with a passion. I needed a set of red markers in the rear, and a set of amber markers in the front. The fronts were damn easy, the rears were a pain, only finding a spot for them. Once I found a 1" LED with a .75" ID that would fit in the fender support, I was set. Snaking the wire was also pretty easy Here's the fender supports with the axle removedHere's a pic of the light and the snaking Once I had the lights all set and I felt that the thing was ready for another inspection, I set about getting a much better way to secure the tanks other than the ratcheting strap and a piece of line. Effective, just not sexy. These tie-downs I've used in the past. I love em. With the hoop removed, al that remains is an anodized dome piece of AL.... and they're supposed to support 2000lbs to boot... I kinda doubt it's that much but whatever. Here it is secured To remove it, you grab the almost H shapped piece, pull up, and slide out Very very quick. But now I needed the same quick and sexy way to get tension on the webbing. I looked at a few different options before deciding on these straight pull latches from De-Sta-Co. I actually used this same latch on the rear swing out on my Cherokee, just a much bigger one. These aren't doing much bit tensioning some webbing to secure a 50lb tank of gas. Don't need all that much so the smaller was definitely the way to go. Released with no tension TENSION! Yup, lots of tension, hold the tank really snug. The last little bit that I can think of is a way to quickly and easily secure the tires themselves. I know exactely how to do it, I just need a tubing bender and I'll be ready to roll with that. Then, break the whole thing down, powdercoat it and then put it in storage till the spring
-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- Last edited by TitaniumTT; 10-30-2011 at 01:22 AM. |
Need more pics
