#76 | |
Don Mega
Very wide! D shaped and extremely tall too. Was almost identical to my old Peripheral Port 13B from back in 1992!
#77 |
very impressive build! i like your choice of volvo too!! my first car was a 122S
![]() ![]() ![]() rotaryshack.com |
#78 |
Bah!
Nice, CNC broacher!
Johnson TA FC in the works! |
#79 |
Rep Power: 15 ![]() |
Time for a little update!
Sadly my HTC Desire isn't the best camera in workshop-lights... Have finally got along with the Keyway! First, I did new irons to the vise (correct name? Google translate) They are mounted from the inside with M10-bolts ![]() A hole at 43.61mm, and an Radius 6.0mm to give clearance for Radius 5.0mm on the eccentric. This is not bored, so the surface is just roughed yet. ![]() Exact precision! ![]() Like a glove! ![]() ![]() Indication of a cam, I have my zero point where I did the fixture, so then you have easy track of the eccentric theory should lie on the X 15.0mm Y0.0mm. ![]() A final inspection of the tool. Indicates the track of the tool in the X-axis, thus I know that it is angled precisely 90grd. Using the M-code M19 in the machine, so I lock the spindle in the same place every time. ![]() This is what working out, it will actually go much faster, when the cutting speed in such a cut is about 80-120m/min, ie as soon as it will go through the material. Easy as it spins to get the cutting speed, but now the cut stands still. So I drive 2m/min or F2000.0 as many may know. Takes just 0.1mm per insert to avoid accidents in my fine pieces ![]() Results! Keyway on 5.00-5.01mm width, and depth with little clearance. ![]()
#80 |
Bah!
I like this.
"First, I did new irons to the vise (correct name? Google translate)" We call these "soft tooling" since they're made of softer material that's easy to machine.
#81 |
SolidWorks is an hard program to learn...
#82 |
Home-brew Rotary
Spaghetti maker?
#83 |
No more rise in my japanese engine
![]() Tonight I made a little keyway in the crank, which corresponds to the ones I did in the eccentric. A male cutter, one must have ... ![]() Important to buckle without moving it! ![]() Finished setup. ![]() work work ![]() That did it! The track is 5.01 mm wide and 43.5 mm long. Easy to forget compensation for the shaft shall be grinded then when you set the depth.
#84 |
Home-brew Rotary
Thats cool.
#85 |
#86 |
#87 |
20b Tinkerer
I love this thread. I bought a cheap mill and lathe a while back and taught myself in hopes of doing something like this one day. It's good to see how it really gets done though.
#88 |
Just for fun...
#89 |
cxxxx|::::::::::::>
Rep Power: 17 ![]() |
so when can we see a 26b kit from you
#90 |
In this speed, about 2025?
