		#16 | ||
				Rep Power: 0 ![]()  |
 Practically this plays out as follows:If we add more R12, both the temperature and the pressure will rise. Then, if we let the system regain it's original 85* temp, it must settle back at exactly 91.7*. Take a little out, the temp and pressure drops. Let the temp regain 85*, you guessed it, back to 91.7. If the gas in the system is pure R12, there is only 2 ways the system can vary from the stated temp/pressure chart. One way is if there is so little in the system that there is no longer liquid available to maintain the saturated vapor pressure. In this case, the pressure will drop below the 87.5*. Or conversely, we can fill the system so completely that there is no room for vapor. The system is then filled with a non-compressible fluid. Then the pressure can exceed the 85.7* Given the low static pressure and the very low lowside/highside pressures when running, your system is likely very close to empty. Look for leaks. It could also be contaminated with another gas that would cause the pressure to vary from the chart. Some would cause the pressure to be lower, most would cause the pressure to be higher. Quote:
 In a properly (or moderately low) charged system, the compressor switches off at about 18psi. and back on at about 35-40psi. If the switch does not switch the compressor off, either the switch is bad or there is not enough freon to cool the coil down to 33* to cause the compressor to switch off. I personally have never seen this occur. Usually low systems cause the compressor to rapidly cycle-on and off. If it is cycling on off in under say 30 seconds it is called short-cycling. You are correct: The compressor should not be able to run constantly at 6psi low side. Diagnostic of this switch is on page 44/45 on the S5 FS. S4 is identical. I hope all this helps you solve the problem. Good Luck.  |
		#17 | |||
				Rep Power: 16 ![]()  |
		#18 | ||
    She quit me instead, lucky break!If that temp switch is gimp, you could have attained vacuum on the low side, but not that likely. I would advise to charge a couple of oz of liquid refrigerant into the system then run the car until everything gets good and hot. Go back to the spray bottle and look for your leak. Pro's use nitrogen and pressure the system up to 200psi to look for leaks. Quote:
 Also,be aware that there are two different systems on the FC. One is installed in Japan and the other was installed at the port of entry. Type is not related to Sanden/Nippondenso system. If you lookup the part number at nearly ANY parts store, they always get the wrong one. Take your old part in with you to save the trip. An easy way to distinguish is the hold down bracket for the drier. If your bracket is welded on, get a replacement that is welded on. If it is clamp on, get the drier that is clamp on. Whether you recharge w/R12 or Freeze12, use Ester oil for lube. Add a couple of oz of oil to make up for losses around the compressor seal. DO NOT use PAG in any system that has pretty much ever had mineral oil or R12 in it. Bad reaction. I don't know if you can easily even find mineral oil any more.  |
		#19 | |||
 Since I don't have a vacuum pump to evacuate the system, I'll have to farm part of this job out. Fortunately I found a local shop who will work with R12 and seems competent and charges pretty reasonable rates. Game plan is to bring it to him to evacuate the system & recycle whatever R12 I have left. If the evacuation shows I have no leaks (holds deep vacuum for a long time), I will take the car home & install a new receiver/dryer. Then bring it back, have the system evacuated again and charged to spec with R12, Ester oil lube and some leak detect dye. If it doesn't hold vacuum on the first evacuation, I'll have him test for leaks with the pressurized nitrogen, and depending on what he finds, I'll either have him fix it there or fix it myself and bring it back for evac/charging as previously described. Thanks for the help!  |
		#20 |
			Yes the new drier will be compatible with mineral oil.
	Buy your drier local so you can verify before you pay your money.  |
		#21 |
			 Bah!
				Rep Power: 18 ![]()  |
			If you need o rings, the kit autozone sells will have enough to last you a lifetime.
	Johnson TA FC in the works!  |
		#22 |
			My A/C is now fixed and once again ice cold, and not a minute too soon with the 100*F temps today! Anyway, it would appear that one of the O-rings on the receiver/dryer literally disintegrated itself over the past 22 years; the ring that came out looked more like a rubber skid mark than an O-ring. Put on a new receiver/dryer, and had the shop evacuate the system for about 45 minutes on a deep vacuum. Then I had them check to verify that it could hold vacuum for at least 30 minutes after shutting off the vacuum pump. It did, so I had it charged to spec with R12 and had them add in some UV leak detect dye just incase. With the temps today at about 100*F, my vents were blowing out air at 47~50*F once it was fully charged, not too shabby.
		#23 | |
				Rep Power: 19 ![]()  |
	'15 Juke Nismo '06 MX-5 GT SOLD '04 S Silver RX-8 GT Track Day Use SOLD '90 Black TII vert w/ Sprint RE stock port/turbo DD dyno (242.6whp@5500rpm @12psi 8psi@redline) and (250ftlbtq@4800rpm @13psi) SOLD '89 GTUs 6p TII SOLD, '87 sport SOLD, '79 SA stock SOLD '91 B2600i 4x4 w/ Rx-8 LSD SOLD  |
		#24 |
			Still have all my limbs, but he charged almost $50 per can of R12, and it took two of them (28 oz). Seems to be the market rate. On ebay, R12 runs about $45~50 per can with shipping from the "buy it now" dealers. You can find it cheaper on ebay auctions and might get lucky, but after bidding on a few of them and not winning, I got fed up waiting.
