Old 07-01-2011, 10:26 PM   #1
NoDOHC
NoDOHC's Avatar
Update:
My previous test setup was not as accurate as I had hoped, so I decided to build a setup that could graphically display what the exhaust was doing.
To that end, I used two Ashcroft K1 150 psi pressure transducers in the exhaust to measure backpressure (watching the pulses on an oscilloscope). These transducers are the same ones I use for compression tests.
Unfortunately, I didn't think that the neighbors would appreciate me starting the car and reving it up right now, so I will have to wait for tomorrow to collect data.
Anyhow, what waveforms do you guys want to see?
I can tell that the headers scavenge well at higher speeds, but I can't get a good scope trace there as the engine revs too fast.
I watched the exhaust pressure at idle and was appalled by how frequently the engine misfires. About every 15th power stroke is a full and complete combustion, the rest are partial or complete misfires. I think that 14.2:1 is a bit lean after all.
I will post some traces tomorrow - what would interest you?
