Old 06-20-2011, 03:38 PM   #1
JustJeff
JustJeff's Avatar
Originally Posted by My5ABaby View Post
You have terrible luck with shops.
Tell me about it!! I guess that's the product of living a pretty rural midwest. I've learned to do as much work as possible, not only out of personal pride, but for sheer survival!!
Originally Posted by tweiss3 View Post
use the razor blade trick to clean it down to bare metal
clean up the turbo outlet port also?
Originally Posted by yzf-r1
Old 06-20-2011, 04:13 PM   #2
You might as well... Even if you cleaned a 1/2" outward of the circle in the middle, you'd have plenty of gasket material... dremel sanding drum??
*** That particular area doesn't see any pressure, so the gasket material doesn't have to be so "Robust". A stock gasket with black RTV would seal no prob.***
