Old 06-11-2011, 07:41 AM   #1
NoDOHC
NoDOHC's Avatar
Having done this numerous times, I find it very hard to understand how they messed it up. it literally takes about 15 minutes to replace stationary gear bearings and requires very little effort (using pineapple racing bearing installation tool).
You should always clean the tool and bearing and install assembly lube on the surfaces before pressing the bearing in.
I am saddened by this.
Getting the tab mis-aligned is not such a big deal (press it out, turn it and press it back in - although obviously you should catch this before it is pressed all the way in), but the scratches are hard to repair.
Best of luck to you.
Old 06-11-2011, 10:56 PM   #2
JustJeff
JustJeff's Avatar
Originally Posted by EasyE1 View Post
3 weeks!? Fail.
The rear bearing is unacceptable period. The front I can't tell how deep the scratches are. But there should be no marking on the bearing surface if the proper tooling was used.
I dropped the parts off and he said no problem, I can pick them up in the AM. I actually forgot about the parts for a week and a half. I stopped in thinking they'd be done. They were still in his office where we left them. He was off property so I called the next day. He said he'd have them the next day. I call next day, they are not done and he is off property. I call a few days later still not done. I give them a week and still not done but he says I can pick them up in the morning.
They had to machine their own tool for the job.
Is this a reputable shop???
This guy is an idiot.
(Journal) bearing material is usually some soft metal like lead, antimony, etc.
http://en.wikipedia.org/wiki/Babbitt_(metal)
Although aluminum's harness is very close to (pure) lead and (pure) antimony, enough abuse will cause damage.
On top of that, you can work harden aluminum to the point where it can get harder than the bearing babbitt surface - any competent person who does metal machining should KNOW this.
http://www.tedpella.com/company_html/hardness.htm
Damage to a journal bearing surface is DEATH.
I bet the aluminum guide / bearing press had sharp edges or the person doing the work was hamfisted or drunk.
Unfortunately I'm running out of machine shops in my town. I was using a machine shop specializing in automotive work. Till that guy convinced me that putting an electric fan temp switch in the radiator would be equally effective as putting it in the water pump housing.
A quality shop turned down the bearing work because they don't do automotive work.
So I went to this shop. The owner/manager seems shady. Not only did he keep promising me next day completion. But I believe he knows his shop did some poor work. When I picked up the gears in his office and started looking them over he got this look of dread...like he didn't really want me looking them over.
When I called him a few minutes later he started rattling off about using aluminum, etc etc. And I kept responding "Well I"m holding the gears in my hand looking at scratches in the bearings.."
About the tool they used...yes they made a guide/press for it and I was thinking the same thing. I bet they did the rear one first and realized afterwards they needed to clean it better.
Depending on what the owner/manager says on monday, I may be looking for someone to do this work. I've run out of shops in my small town. If I decided to mail them off to someone would you do the work and how much would you want?
Originally Posted by yzf-r1
