Old 06-02-2011, 12:12 PM   #1
mazpower
Rawr Bearclaw
mazpower's Avatar
The rear end is done!
Front diff mount bracket
Adapter piece to go from 3 bolt flange to 4 bolt
New beefy driveshaft, good for 500 hp
New axles...thicker and heavier than stock. Good for 400 hp
Gotta do something with that fuel line...its not touching the driveshaft but its too close.
I drove the car last night for the first time since November. I'll get video later!
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
Old 07-04-2011, 04:21 AM   #2
HickamHatch
HickamHatch is on a distinguished road
Which haltech model are you running? I have platinum sport 2000 from
Old build and was hoping to use it on my ls1 but i see that the it only goes to 6 cyl direct fire. Please let me know how you set up your haltech and which model. Thanks!
HickamHatch is offline   Reply With Quote
Old 07-05-2011, 10:31 AM   #3
just startn
Turbo Vert
just startn is on a distinguished road
Deff needs 2 turbos.
just startn is offline   Reply With Quote
Old 07-05-2011, 10:41 AM   #4
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
i'm not sure where they would fit.
Old 07-05-2011, 10:52 AM   #5
Rear mount. Plenty of room where the muffler sits
Old 07-05-2011, 10:52 AM   #6
mazpower
Rawr Bearclaw
mazpower's Avatar
I'm running a E11v2. You can run a LS1 no problem with a P2000S. You'll have to set it up to run sequential injection and waste spark ignition. Just pair the cylinders for waste spark (one on compression, other on exhaust stroke) and use the 4 ignition outputs. Make sure to use the earlier 24 tooth wheel, not the newer 50-something tooth wheel on your crank.
Yeah that would be interesting.
Illicit Performance
