Old 06-02-2011, 11:44 AM   #5
88turboii
destroy, rebuild, repeat
88turboii's Avatar
an easy way is turn the engine over while holding the spark plug connector slightly off the post and see if spark arcs. you could also simulate engine turning over by taking out the CAS and spin it by hand with the key in "run" position
to benchtest it, just find the pinout and use 12V on one pin, and briefly ground the other and you should see spark arc
