#1 | |
another problem on used housings, this is why they shrink, and why we measure for width, is that the steel liner actually collapses in the compression area, so the center of the housing bows in. its very bad to have leakage between chambers... mike Last edited by j9fd3s; 05-30-2011 at 04:45 PM. |
#2 | |
Notice the temps where we want to provide extra cooling are doubled that of atmospheric boiling water. Barry
that very well could be. next time you have some used housings handy, take a straight edge and lay it across the surface, its above the spark plugs that seems to do the worst.
i did build a couple of motors with a stock diameter stud kit, and i was told to tighten it to 50lbs, but i think this is actually bad. it also certainly didn't solve the actual problem which was stock ecu/injectors with a street port and big turbo! or more correctly the owner. after thinking about it, i think the small diameter studs actually hurt more than they help. the studs DO NOT locate any of the housings any better than the stock bolts, plus #50lbs of torque the rotor housings probably ARE bowing, which is bad! mike |
